HeavyDuty »
https://forums.nicoclub.com/heavyduty-u10182.html
Fri Aug 14, 2009 12:44 pm
I don't know about an 04 specifically, but I'm looking at a disassembled 03 and the bellhousing is integrated into the main case of the transmission.
That is to say, someone else would have to tell you if you can take the main and input shafts and all the gearsets and all out of the 06 and install them to work in the 04 main case/bellhousing.
There's a small tailshaft that bolts on to the end of the main case and then a "bridged" or extended shift linkage mount bracket on the very end.
On the back of the engine and the front of the transmission, on an 03, at least, there's provisions for a LH or RH starter. Is the starter on the 06 on the driver's side? If so, doesn't the 06 have dual starter...ports also?
Modified by HeavyDuty at 6:57 PM 8/14/2009
