swappin' qweschun
droptopsilvia
just wondering If a 97 ka w/ manual will drop into my 93 auto? what would I need aside from the cluth master and slave cyl. and lines, brake and clutch pedal. to make the transmission work I wont need any ecu work right?
thanks.
Nismo_Freak
Car: 89 Nissan 240SX
You'll need the 97 ECU ... apart from that you need the clutch position sensors, lines, clutch, master and slave cylinders, resevoir, and misc. wiring that you'll have to do.
You'll have to bung in a 2ndary 02 sensor ... cause the 97 is OBDII.
droptopsilvia
danke...grazi...thanksI didnt even think of obdIIoh well the engines gone anyways shouldve figured..
