Swapped the Diff and transmission Oil by Accident
Phantom Gett
Car: 1996 Nissan 240SX SE
So... I may be mildly dislexic... Because I changed my gear and diff oil recently in my 96 240 and I accidentally swapped the oil viscosities between the two. I put 80W-90 in the Transmission and 75W-90 in the VLSD...
Will this have any short term or long term adverse effects and should I swap the oil ASAP or not worry too much about it? Just realized it (a week later) and wanted a quick (but educated) opinion.
Sorry if this seems like a stupid question, I've never changed gear or diff oil before? Only crankcase oil, so I'm not really sure. Common sense says they probably aren't too different but also that they are different for a reason... So any help would be appreciated
Nope - they're absolutely fine.
Both will perform as usual with the "wrong" fluid. Hell, you did a good thing by having clean fluid in both!
Towncivilian
2007 Nissan Altima 2.5L CVT
2012 Infiniti G37 Sedan 7A/T
If the 80W-90 you put in the trans is GL-5 or claims "GL-4 and GL-5 compatible", you should probably drain the transmission and fill it with a GL-4 only fluid such as Redline MT-90, Amsoil MTG, or the stock Nissan fluid. The GL-5 fluid can harm yellow metal (brass synchros), which I'm assuming your transmission has (correct me if I'm wrong!), so a GL-4 fluid is preferred and is what is specified in the maintenance section of the FSM. I think LSD additive, if present in the gear oil you picked, can also cause slippage.
As for the diff, I'm not quite sure to be honest. Hopefully someone else will chime in.
Phantom Gett
Thank you for the reply, it was bugging me so much I couldn't sleep <-- noob
Actually asked a dealer before buying the oils, they told me APi-GL5 was okay to run. It's got Royal Purple 75W-90 in the Diff and Vavoline Sythetic blend 80W-90 in the trans. --- but correct me if I'm wrong.
asoomal
Car: 2001 Subaru Impreza L 5MT (Daily)
1992 Nissan 240SX SE 5MT w/HICAS (Being restored)
GL5 is not okay to run in those transmissions.
Drain it asap man!
Hoffman5982
Car: '95 sr20det 240sx
Drain the transmission and put some Penzoil synchromesh in it. I've used it on both my ka and sr and have never had a problem
Towncivilian wrote:If the 80W-90 you put in the trans is GL-5 or claims "GL-4 and GL-5 compatible", you should probably drain the transmission and fill it with a GL-4 only fluid such as Redline MT-90, Amsoil MTG, or the stock Nissan fluid. The GL-5 fluid can harm yellow metal (brass synchros), which I'm assuming your transmission has (correct me if I'm wrong!), so a GL-4 fluid is preferred and is what is specified in the maintenance section of the FSM. I think LSD additive, if present in the gear oil you picked, can also cause slippage.
Ah, my bad - I forgot about Nissan transmissions and their brass synchros.
Dammit - I'm gonna go back to my cage...
Towncivilian
RP 75W-90 is great for the diff. Just get some good API GL-4 fluid in the trans and you'll be set. :dblthumb:
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
GL-4 only.... GL-5 expands soft metals aka the brass bushings and syncros. Amsoil or reline in the trans, diff whatever you want as long as the weight is good
ddgsxr504
Car: 1995 Nissan 240SX SE 2007 Infinit M35 Sport 2011 Nissan Pathfinder Silver Edition
Yea it was always hard for me to find GL-4 transmission fluid in Cali unless I special order it. I used to put Valvoline Synthetic 75W-90 in the transmission and on cold morning that bastard did not want to go into second, felt like I was trying to Lat Row a 60lb weight. Been running Royal Purple ever since and with 230,000 miles it still shifts like butter.
240sxAli4Life
Car: 1990 S13 Hatch SOHC... SOLD :(
1993 S13 Hatch DOHC!! Super Sexy!!
How the hell did you manage to do that??? LMAO!!!!
PEZi
Whadda ya know... our new mod knows some shiz!
See above
