Swapped engines and can't get it to start :(
Florida240sx
I swapped engines and can't get the dam thing to run. When we shoot starter fluid in the intake it almost takes off but stopped because didn't want to crack a piston. I got 2 hoses that are missign and not hooked up but it's the real small ones. My friends ripped all my crap off so I got no idea where my hoses go.There any diagrams pics of where all our lines run?
Structure240sx
did you have to re-install the distributor? does it start at all? IACV hose hooked up (next to throttle body)? are u getting fuel or spark?
frapjap
'07 Subaru Legacy
Timing issue most likely. Look for the thead titled SWAP! ka24e to ka24de
Florida240sx
same engine. ka24e i'm getting spark to the plugs.couple vaccum lines...but should just make the car not idle right
yellow_jacket
Car: 95 240sx
If the car did not immediately fire up with starting fluid, but instead chugged a little then you probably have the distributor off one tooth. More than likely, it is one tooth retarded.
Florida240sx
Car starts while spraying ether.But dies immediately.My friends had the fuel lines reversed....what can the problem be now? Getting spark.
frapjap
'07 Subaru Legacy
Please, check the timing.
benemorius
Car: s13, s13, eg, e36
Indeed - check that timing. Also check fuel pressure. And what was that about fuel lines?
Florida240sx
My dad checked the timing for me. dist. c ap was never removed.Maybe clogged injectors?
benemorius
Clogged injectors? Maybe....
benemorius wrote:Also check fuel pressure. And what was that about fuel lines?
frapjap
'07 Subaru Legacy
The car has to be running in order to use a timing light. My distributor was never removed either, but it was still waaaaaay retarted. Also, what year engine and what year chassis are you using? if its a dohc into a sohc chassis, youre going to need the 91-93 series distributor.
gumby
Car: '89 240sx sohc
is the fuel pump working? maybe the relays shot
Florida240sx
fuel pump is working i just swapped a blown ka24e with one that was running been sitting for a while though but was indoors
