If pic didnt come through, see it here:
http://datsun510.com/photopost...ort=1
Engine: S13 RedtopCylinder Block bored 0.020” over (1/2 mm)Short block blueprinted and balancedProfessionally assembled with Forged Wiseco pistons (dished) - 8.5:1 C.R.CNC/Hand finished porting of Cylinder Head on Exhaust side, Hand ported intake sideComplete Valve JobResurfaced headGReddy 1.2mm Metal Head GasketStock Cams/ValvetrainCustom 3-core C&R Racing RadiatorSPAL electric cooling fan
Engine ManagementSpeed-Density conversionCustom Crank Angle Sensor DiscAEM Programmable Engine Management System (Modified Mitsubishi Lancer Evo8 pnp EMS) AEM 3.5 bar MAP SensorAEM EGT sensorAEM Fuel pressure SensorComplete custom wiring harnessAEM Wideband UEGO Sensor (Oxygen Sensor)GM Boost Control Solenoid (controlled by AEM EMS)AEM Capacitor Discharge Ignition SystemStock Nissan Coils on plugsNGK Iridium Spark Plugs
AIR/Fuel DeliveryGarrett S15 Silvia T28 Turbocharger: Compressor side-60 trim T-3 BCI-8 wheel in a.60 a/r TO4B housingExhaust side- 62 trim T25 turbine in a .64 a/r housing (Running 9psi low boost and 16psi High boost)Custom Exhaust Manifold from JGS Turbo, OEM metal gasketsCustom 3” Stainless steel TIG welded Downpipe (turbo flange from JGS Turbo)Custom stainless steel heat shield for TurbineFull custom 3” 304 Stainless Steel exhaust system, Magnaflow 3” stainless steel straight-thru mufflerTial 35mm External WastegateSpearco Intercooler core with custom end tanksCustom 2.25” aluminum intercooler pipingGReddy Type-R Blow Off ValveCustom Modified Fuel Rail with AN fittingsAEM Fuel FilterAEM Fuel Pressure RegulatorCustom 3/8” stainless hardline and –6AN Fuel linesNissan 300zx (Z31) in-tank Fuel PumpModified compressor air inlet horn from Precision TurboCustom 3” Aluminum Air intake systemAEM Air Filter100% Earl’s Performance fittings
DrivetrainS13 5-speed manual transmissionShortened 510 DriveshaftACT Street ClutchHKS Cro-Mo FlywheelCustom Transmission CrossmemberSubaru 3.70 R160 Limited Slip Differential
