naed240sx »
https://forums.nicoclub.com/naed240sx-u28231.html
Fri Jan 13, 2006 2:46 pm
Ok, so I swapped the brake pads and rotors from one of my s13's to the other. So now 240 #1 has the pads and rotors from #2, and #2 has the pads and rotors from #1. Before the swap, #1's pads and rotors were practically new, while #2's were pretty worn. Both cars were braking fine before the swap. Now, #1 will hardly stop, and the brake pedal travels to the floor with ease.
Is this because the pistons were farther out on #1 to begin with, and now cannot clamp down on the essentially slimmer old pad/rotor combo? I adjusted the rear piston by turning it outwards, but the fronts couldnt really be adjusted. How can I fix this?
