NCYankee »
https://forums.nicoclub.com/ncyankee-u117889.html
Wed Jun 10, 2009 9:57 pm
I thought about resurrecting my old thread from a few months ago but most of the info I gave then was more or less useless so I decided to save everyone from reading 13 or 14 obsolete posts.
To rehash - I spun out and hit a curb a while ago at low speed, prob less than 5 mph. No tire or rim damage, but something got bent.
The result was extreme positive toe, 1.37 deg, way past the .21 deg max. Camber is also a little out to the positive side as would be expected after a low rim shot, -.45 deg (spec is -.60 to -1.60)
I replaced the rear toe link, because the bushing was history - didn't help at all, other than maybe a little more stability because the inboard attachment stopped wandering around, but it didn't change the alignment specs.
Today I replaced the RLCA, because it appeared that the front attachment was a little bent - and it was, but only slightly, I took measurements with a Vernier caliper and one of the bushing brackets was torqued slightly down and in, but not more than 1-1.5 mm - prob not enough to cause the toe to be that far out of spec.
I haven't had the alignment checked yet (I got the lifetime alignement at Firestone) but I am pretty sure it's still way out - though I set the toe back to where it was, max negative, a rough check with a straightedge across the tire shows it still hitting the edge of the wheel well in pretty much the same place as before.
I also had a hard time getting it back together, with the ball joint and rear bolt in, the front bolt was still about a half inch out - it took some creative (but very light) use of the jack on the rotor hub to help me push it into line. This misalignment also suggests the toe is still way positive, and pretty much eliminates the front toe link - if it were bent in a way to cause pos toe, it wouldn't have held the bolt away from the hole.
I guess that leaves the RUCA, hub or the subframe or subframe attachments.
How likely is the hub to have bent on a low speed hit that didn't even damage the tire or rim?
If I post good hi-res pics of the front RLCA mount point would someone be able to tell if it was bent?
Could the RUCA get bent in such a manner as to cause pos toe and camber on a low rim shot? I can't visualize how that could happen, given the stresses that would result from such a hit.
