swapped 1999 altima engine spins no spark
General discussion area for the L30-chassis Altima
themanhandler
Car: 97.98.99 ALTIMAS
hi swapped in engine, no spark and just spins . Do i need to reset the ecu is it an alarm issue ,factory altima alarm old engine was running had thrown a rod What is the reset procedure on nissans IE ALARM OR OBD ,ECU ECT. THanks the manhandler
themanhandler
HI SWAPPED A 99ALTIMA ENGINE NO SPARK OR FUEL ENGINE CRANKS FINE ANY RESET PROCEDURE ETC THANKS THEMANHANDLER
cesar240sx
Car: 93/240sx turbo/nitros
make sure the crank position sensor connector and the condensor on the distrubitor connector are not crossed...good luck..check wiring color
Return to “2nd Generation Altima Sedan (1998-2001)”
