twofourzeroSX »
https://forums.nicoclub.com/twofourzerosx-u15347.html
Mon Apr 10, 2006 11:04 am
i agree with everything that has been said...but also... remember when taking the turbo off to take it off as a manifold/turbo/ turbo elbow assembly...and disconnect the oil and coolant lines from the BLOCK NOT THE TURBO. that will save you alot of headaches. unless you drain the coolant from the radiator expect for it to spray all over when you unbolt the line. the oil isnt that bad. The coolant feed is behind the block and can be a real ***** to do. OO and dont forget the lower oil return rubber hose
as for instalation, i havent put my t28 on yet but when i put the t25 back in i did the following...
if you are reusing the stock lines try to loosen up the oil line on the front of the turbo, keep it loose enough so that you can wiggle it. that way you can set the manifold on the studs, and connect your oil and coolant before the turbo is tight. Just be sure to Retighten that oil line. The coolant send on the back of the turbo is a real pain to put back on, i recoment using a screw type hose clamp, not the factory crap.
if you are using braded lines i believe that u cant get to the place where the coolant feed hooks up to without pulling the motor.
OO...and dont forget to hook up the vac. hoses!! (no seriously, no wastegate signal = blown turbo or engine)
thats all i can think of right now..good luck
