Vegascorbin »
https://forums.nicoclub.com/vegascorbin-u82093.html
Tue Mar 17, 2009 8:19 am
When you unplug everything be sure to mark where it came from. I used Ty-wraps from work that have a small space to wite on. Others have used the plastic things you get from bread wrapers. You can use tape or whatever else you have available but mark everything.
If you dont know the name of something then put where it came from, such as: third connector to the left of the oil filter, or right side near injector #1.
That will save TONS of time when you go to put back in. Also you can take pictures of your tag and the connector before you unplug.
Spring for the Pizza and beverages to get a friend over to help. much easyier and safer.
Have fun and be safe.
