swaping ka24e to ka24de
moneymike
Car: 1991 nissan d21 hardbody
i have a 1991 d21 hardbody and im planning on swaping out my ka24e for a ka24de. my friend has a 1995 240sx and i was wondering if it would bolt up to my mounts, i think the 1995 240sx is s14 so if i try to bolt it up would it fall right into place? and i plan on doing the transmission as well.
seang
Car: Ford Fiesta ST
Mounts are the same. transmission's might have different shifter locations, but don't take my word for it I haven't seen them side by side. I have also read that there are sensors in different locations on the transmission from the 240sx.
There was a write up for this exact question, but I might have to find it later.
Desert Rat
Car: 2014 370Z M6 Base Coupe
2017 Frontier 4.0
2007 Dodge Ram 2500 Cummins Quad Cab 4x4
1977 F150 4x4 Shorty BUILT
2008 Boulevard C90T
Previous owner of a bunch of Nissans
Search this forum. This question has been asked dozens of times.
moneymike
can i just use the stock transmission from my ka24e and use it on the ka24de?
seang
Car: Ford Fiesta ST
Moneymike, did you get the Email I sent you?
silveradobeast
Car: 94 HARDBODY 2.4 5 SPEED
94 d21 5 SPEED 4X4 EXT CAB
PARTINNG OUT A D21
whats the difference on the e and de?
moneymike
e stand for electric injectors and the d stand for dual over head cams
silveradobeast
PARTINNG OUT A D21
i guess more hp?
moneymike
yea 15 more hp but its alot stronger and can withstand alot more abuse
seang
Car: Ford Fiesta ST
moneymike wrote: but its alot stronger and can withstand alot more abuse
Please elaborate, because there are 700hp ka24et's, and GT3 NA 300hp ka24e's.
I know ka24de's have more stock head flow, and solid lifters stock, but the rotating asseblies are the same, other than different compression ratios. Worked over ka24e heads can flow as much as a stock DE head.
There is no reason to shy away from a KA24E. I would like to take one, put solid rockers, and nice forged rods and pistons in it, boost it, and make sh*tloads of power with it.
Don't get me wrong, I'm not downing the DE, but there is plenty of potential in an E.
Modified by seang at 4:36 PM 12/27/2009
silveradobeast
PARTINNG OUT A D21
good to know!!
