swaping ka24de into 89s13 info
Crazyracer77
ok well my car is leaking oil from every seal and gasket and i pulled the motor last night and i have a choice of buying a 98 ka24de for 300 or a ka24e for 200 which is just a complete long block without the madifolds. well anyways just wanting to know what all i need to swap the dual cam in, i know i need the wiring harness ecu and what else??? thanks
Sonikfuri
Car: S13 Coupe
This link: http://www.nicoclub.com/articles.php?id=162443
-its a complete swap guide.
S13DrIfTmEkAnIcS
Car: 89 240sx
direct bolt in, you can use the E transmission too. the only thing u need is the dual cam wire harness and ecu. for the tach to work you need to get a dual cam cluster and do some custom wiring but thats all
