Dud
mcheddadi wrote:What do you guys think about me swapping my Eibach 3.5SE springs for Eibach 2.5S springs.
I'm trying to achieve a softer, more comfortable ride.might even remove front sway bar just to see the effect.
I'll get dissed for this for sure...but I got a great ride...
On the exterior, my drop looks identical to a typical Eibach prokit drop, front and rear...but it its not your typical Eibach drop...
I have the prokit springs in the front...in the rear I left the stock springs and weighted the trunk (literally) to compress the rear springs (whihc also "lowered" the rear the equivelent of the Eibach rear spings).
Then, I removed the rear sway bar (not the front...wouldnt do that) to allow each side to operate independantly from the other...while the rear bar ties in the sides, it also makes the ride stiffer and bouncier...I really noticed very little difference with the RSB off...insignificant roll or sway increase, but much less bouncy and stiff.
This has resulted in a car that is "dropped" but a ride that is MUCH smoother yet still firm, and it hugs the road great. ANd for all who want to flame, flame on...but it handels, corners AND looks great.
While it is a very unorthodox idea, it has given me the ride that I was after with the drop I wanted. And I have now put 18,000 miles on the car, everything is still working great, not problems, from speed bumbs to cornering...low speeds or high.
