Swap wiring problems....
clever240sx
Car: Nissan 240sx
I just did another sr swap but this one is giving me some problems. I just got the wiring back from wiring specialties and i cant figure out what these two plugs go to? Also when i try and start the EGI Pump relay clicks?
Any suggestions?
clever240sx
Car: Nissan 240sx
Well i shouldnt have even posted this. Right after i did i went out there and saw i had no ground to the block. Hooked one up and it fired right up. Runs amazing! This always brightens up my day
J240sx
Car: 89 240sx
lol, well congrats on the start up. I will be attempting to start mine tomorrow for the first time. Wish me luck
Onizuka
Car: 91 Nissan S13 coupe SR20DET
89 Nissan S14 hatch SR20DE
ever find out what the plugs were for?
clovers525e
Car: white 93 coupe, s14 sr
J240sx wrote:lol, well congrats on the start up. I will be attempting to start mine tomorrow for the first time. Wish me luck
how'd it go? thats what i did today too, but alas, no luck.
duffman1278
Car: 89 240sx Hatch, the wildcats!
The grey one almost looks like the Coolant Temperature Sensors plug. However I don't want to say it is because I believe they're usually red.
clever240sx
Car: Nissan 240sx
I almost think your right because i finally got the car running tonight and took it out for a drive and the coolant gauge was not working.Ill look tomarrow for sure
duffman1278
Well there's 2 for the coolant temp. One is for the gauge which is a single pin connector, then there's the one for the ECU. Which is the 2 pin connector.
SlideWayzS13
Car: 89 S13 coupe Swapped srBlkTop
The black one on the left is for the stock KA fans. I had to look for that plug forever if you ever run Haltech thats the sender wire you hook the fans up to.
clever240sx
Car: Nissan 240sx
That plug wasnt for the coolant temp..it is a red plug but i dont understand why my coolant gauge wont work? Its a 89' 240. Do i need a sohc coolant temp sensor?Also for the fan plug, can i just cut those wires and run them to my 14" fan i have so they run all the time? Or is that just set up for them to run when the thermostat opens up?
