swap to a intermittent wiper switch
nec ozzi
I got a intermittent wiper for my 1990 hardbody that has a regular wiper switch does anyone know where the extra pigtail connects to.
RT22
Car: 1991 nissan hardbody
You do not have the wires or the motor and relays to swap direct checked into this myself. Cheapest is jc whitney that has a int switch you add on and control seperately. To convert you need wiring and motors with relay circuit along with the switch.
mrecoolgar
Car: 1990 Hardbody Reg Cab 2WD 2.4 5SP
You do need additional wiring and the module.
I relocated the module from on the wiper motor under hood to inside behind the dash.
Wiring was easier that way.
Here are wiring schematics I made.
RT22
So the module on the wiper motor is all that is needed besides switch and additional wiring? I may hit the junk yard if that is all. On you schematic are the splices and adds on the bottom figure all that is needed to be done? Is that the module from wiper motor?? Thanks for any help I would love to do this.
longtooth
Car: 89 d21 HB
Yes would also like more information. not having intermintant blows.
mrecoolgar
I spent more time on my diagram.
Red indicates the intermintent module, wiper switch connector and related wires.
Blue indicates the one wire that needs to be removed from the wiper switch and added to the intermintent module.
The wire that it replaces needs to be removed completely.
Black indicates existing components that stay untouched.
There are 3 or 4 splices that need to be done.
StephenG
Car: 93 Nissan Hardbody 2wd KA24E 5spd
87 Nissan 200sx CA20E 5spd
Can't wait to do this to my truck, thanks for the very detailed diagram!
Midnight Tech
Car: 86.5 D21
84 Maxima
Same here, sir! I never thought of moving the wiper amp under the dash - will be doing the same with mine.
RT22
What does the module look like? May i email you when I go to do this isf I get stuck or lost? Thanks.
Midnight Tech
Car: 86.5 D21
84 Maxima
RT22, it should be a squarish beige/tan box attached to the wiper motor with a clamp.
RT22
Thanks so the module the stalk and some rewiring is all it takes?? Man I have wanted them bad but never knew what all went into redoing them. it drizzles here all the time and not having INT wipers blows, should be stock on all cars LOL
longtooth
Car: 89 d21 HB
RT22 wrote:Thanks so the module the stalk and some rewiring is all it takes?? Man I have wanted them bad but never knew what all went into redoing them. it drizzles here all the time and not having INT wipers blows, should be stock on all cars LOL
I agree :biggrin:
damagecontrol
Car: Nissan Sentra - CA18DET
Nissan Skyline R32 - RB25DET
Hey guys,
I know this is an old post and a long short but im just wondering if anyone have information concerning this relay. Im having big problems trying to get this hooked up right.
Any pictures and details would be awesome.
I saw there were some photo's posted in 2010 and since been deleted.
Thank you in advance!
