homeslicej2 »
https://forums.nicoclub.com/homeslicej2-u54419.html
Fri Mar 09, 2007 2:59 pm
Well, I'm glad you're expanding your horizons a bit. You never mentioned that the KA was no good, and I'm certain that I said turbo it if the motor was in decent shape. Since it's not, then your cheapest route (and most straightforward swap) will be an SR20 from an S13, redtop or blacktop, or the CA18. Check out the SR and CA forums to determine which you prefer and to get ideas about power levels, both stock and with lite mods, and you'll also learn how to go about installing the motors into your car and what to change when installing them. Both will get you into the 15's with minimal mods. The SR has a larger aftermarket, so if you plan on upgrading later keep that in mind, but that doesn't mean the CA would be out of the question. Plus, seeing that you used to be a honda guy, you might like the 1.8L CA better. I don't know. That's for you to figure out. If you have a lot of money laying around consider one of the RB's, or some kind of V-6 or V-8, or just rebuild the SOHC and enjoy turboing it, tuning it, and building it up yourself. That's my one-half cent.
Oh yeah, cussing out the mods (both d!ck and WD are mods) when you don't like what they say on their forum (I have not read whatever has happened in the other thread) is not usually a good idea.
