Night_Stalker »
https://forums.nicoclub.com/night-stalker-u80588.html
Mon Nov 26, 2007 2:02 pm
so i am almost done collecting parts for my SR swap, i have a couple of things that i am putting in with the engine, and i am wondering if i should upgrade my turbo with the swap, i figure my choices will give me a big enough increase from the stock SR that i wont feel the need to upgrade my turbo yet. if i do, now or later i am thinking about the Garret 2871R - SR20DET Drop in replacement. i am still looking into it to make sure it will work, it looks like i only need the s15 turbo piping adapter kit for the s13.... i know its probably overkill for my stock internals, but if i dial it down a bit it should be ok until i get my engine guts up to snuff..... but anyway, going in with my swap is a set of Easy Cams - Tomei, I think (got a deal on brand new ones from a guy at the tuner shop, still in the box. i dont know thier specs), 3" Cat-back Exhaust, 3" test pipe, 3" Circuit Sports O2 elimination downpipe (downpipe and turbo elbow combo, with an oval bottom that sits flush with my under frame), Megan racing manifold (if i do upgrade my turbo i will probably buy a JIC), Greddy Spec-M FMIC, an HKS Racing Suction Intake Kit, and a Greddy E-manage ECU.... thats about all i can figure that would affect the power... obviously, its not all thats going in with the swap...... but it's all i figure will affect the power..... maybe the carbon lsd will be relevent.... carbonetics 2-way for the VLSD punkin... if i can source one... having issues.. if not KAAZ 2-way.
but anyway, back to the question at hand. i dont know how far over the stock 205ish hp and 203ish ft/lbs my accessories will put me but i ballpark high 2s.... but honestly, i have no idea.... if anyone could hazard a guess, and give some feedback on wether or not i should upgrade my turbo now, with the swap, or if i should wait until the thrill is gone and then do it.... my suspension is already done All fully adj. links, Adj. LCA's, Sway bars, Tower bars, bigbrakes on the front (matched pads on the back) and wheels are 17x8.5 215/45R17 in the front and 205/45R17 in the back except for the Stance GR+PRO Coil's that are going in in the summer, when i take my winter tires off.engine bay is getting stitch welded during the swap, so my chassis can handle to 500hp (probably)all i am worried about is IF i upgrade to this turbo, will it put my cars numbers around 400-500hp? cause that would out-class my skill level...... and if so, i will definately wait until i adjust to a more powerful car (owned a camaro that was pushing 350 at the wheels, but it was the fastest thing i owned, so my skill as a driver still needs to grow)
but anyway, holy lecture... any opinions? comments?
