Zero260 »
https://forums.nicoclub.com/zero260-u34180.html
Sat Feb 04, 2006 5:33 pm
it sounds like your're talking about the clutch dampner, which is just a loop that the hardlines screw into. if that's what it is, you don't need it, it'll make it so the pedal feels more firm, which I like, gives you better clutch feel. you bleed the clutch lines at the slve cylinder, all you do is unscrew the bleeder, and let some fluid out, mkae sure not to let the resevoir go empty.
