swap problem????? help!!!!!
yazzoo
ok, I have the motor in the bay but it is slanted to the left, like if my left leg is shorter than the right. both motor mounts are all the way down i believe, and i have tried to bolt down the transmission mount but it isn't even with the bolt holes. help i need my car back it has been down for 6months. please help......
Silvia007
Car: 93 Nissan 240SX SE Fastback
It's suppose to be slanted, but the way you made it sound is weird, here's how mine looks.
ETTInnov04
Car: 1989 Nissan 240sx fastback
You could try loosening up the motor mounts, dont take them off just loosen where it bolts to the subframe. Then try to line up your trannyand tighten your motor mounts down again. Try and see if that works
Henry G
Forget all that... just take a pic from a few different angles, and we'll let you know if it's angled too far.
mallbor240SR
Car: 240sx 1990
about the transmission mount you are supposed to use the braket from yout KA transmission, not the one that came with the SR , thas why the wholes are not in line
daryl337
Car: '90 240sx
Alright... that might be true... However I find that I am also in a very similar predicament. My Sr (S13 redtop going into my fastback) sits (in its mounts) 1" too far back. I know this because my driveshaft no longer bolts up. -.-
Henry G
What year 240 are you putting the SR in daryl337?
