swap price?
s14kouki
Car: 1998 240SX SE
$4800 flat
1996 sr20det s14 motor into my 1998 240sxauto to manual swap everything done for me i dont need to look for any parts or anythingthey run compression test toobut they said i will need to find someone else to do the Air conditioningis that a reasonable price?
BTW do u guys noe anyone in the 626(southern california area - prefer san gabriel valley) that knows how to fix the air conditioning after i do this swap and for how much?
THANKS ALOT IN ADVANCE
s14a
Car: 98 240 white
damn, i ned all that done toostupid *** auto....
yellow_jacket
Car: 95 240sx
They should know of an airconditioning shop that can fab custom lines. You can then use the SR compressor. IIRC the S14 compressor won't bolt up at all with the S13 SR's, but it may bolt up to the S14 SR. Just research it.
Just curious, how do you plan on passing the OBDII emissions testing? I believe California uses this and it actually requires them to tap into your ecu.
s14kouki
Car: 1998 240SX SE
i have friends....:D
