swap parts!
collk88
ok im a little confused. now if i end up getting an sr20, im having a guy my dad knows do the swap. what comes with the engine when you purchase it? does the stock engine come with a blowoff valve or is that something that is not needed right away? also does the sr20 have a stock intercooler or is that also something you can add down the road?? what do you have to have if im going to just run the engine stock till i have enough money to tune it.
BuudWeizErr
Clips come with side mount intercoolers and recirculating valves.
Now what condition they will be in, that depends on YOU and who you buy it from.
vapor_skank
You wont need a bov right away but it would help keeping the turbo healthy , about the side mount intercoooler that would be fine for running stock for awhile but when you start tuning or whatever you'd want to go with a fmic. Everything from the front clip should take care of the swap but i guess that all depends on the condition and counting on everytihng is included in it as buudweizerr said.
ps: changing the clutch is also a good idea, most are burnt out.
