Swap Out Radios?
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
dfc222
Car: 2009 Nissan Versa 1.6 5 Speed
I have the 1.6 model with the standard factory am/fm/cd unit. I was wondering, if i was to buy the upgraded 6 cd changer version, could i just swap the old one for the upgraded version without any extra equipment?thanks
NODES
Car: 2007 Nissan Versa SL (Blue)
YES
tsfarling
I have the 1.8 S Model with the am/fm cd radio and I was wondering the same thing. Can I buy the upgrade 6 disc cd changer and aux nissan radio and install it plug and play without doing anything with wiring besides plugging it in? Getting ready to load up my Versa its an 07 S
tsfarling
You're versa inspires me
superskunk
Car: '07 Nissan Versa S Hatch
'06 Nissan Murano SL
it is cool to upgrade to the factory unit... but if you plan to add aftermarket sub and amp, then i would recommend you just buy an aftermarket head unit...
VersaMG08
Car: '10 Mazda 3 s hatchback
'14 Nissan 370z
I have an aftermarket sub & amp with aftermarket speakers, but using the stock 6-disc changer. It sounds decent for the most part.
Codelicious
Car: 1989 Nissan 240SX
I'm also using the stock HU but am using 2 10" rocksford fosgate subs and a jenson amp.
It sounds great. A LOT better than what it sounded like stock. Now all I need to do is get new speakers around the car to make it even better!
tsfarling
i just want the upgraded unit for the ipod feature and the 6 disc. im not too worried about bass thumping or anything like that.
superskunk
VersaMG08 wrote:I have an aftermarket sub & amp with aftermarket speakers, but using the stock 6-disc changer. It sounds decent for the most part.
yeah rite... there isnt a high pass option for the factory units... plus aftermarket units offer up better output compared to stock head units... but if you really want one.... i know of someone local to LA that is selling a 6 disc SL model for cheap....
VersaMG08
'14 Nissan 370z
superskunk wrote:yeah rite... there isnt a high pass option for the factory units... plus aftermarket units offer up better output compared to stock head units... but if you really want one.... i know of someone local to LA that is selling a 6 disc SL model for cheap....
No, Im already using the 6 disc changer. If I get an aftermarket headunit, it will be single disc since I'm using my Ipod for playing music. But I understand what you're saying about the high output. I'm not getting the full potental out of the speakers.
tsfarling
i swapped out my radio with and SL radio with aux and it works great except for one thing. when i turn the dash light dimmer on it makes this buzzing noise constantly and when you turn the dimmer switch off then all noise is gone. anyone know what this could be caused by? does the versa sl radio need a bigger fuse or something. it only does it when im in auxillary mode and maybe it has to do with it being an iphone that im using. i switched the iphone into airplane mode but the sound didnt go away. any help would be great thanks!
Codelicious
tsfarling wrote:i swapped out my radio with and SL radio with aux and it works great except for one thing. when i turn the dash light dimmer on it makes this buzzing noise constantly and when you turn the dimmer switch off then all noise is gone. anyone know what this could be caused by? does the versa sl radio need a bigger fuse or something. it only does it when im in auxillary mode and maybe it has to do with it being an iphone that im using. i switched the iphone into airplane mode but the sound didnt go away. any help would be great thanks!
Luckily I have an iPhone and can hopefully answer this for you..
When I am driving I basically just only use my iPod via the aux port. Sometimes when I am going to receive a call/sms my stereo will make a weird buzzing noise and them "ring" I have a phone call.. I'm guessing that it has to do with the phone signals being sent/received. I'm not 100% sure, but I think that even though you turn your iPhone into Airplane mod that it still will send/receive data which is probably whats causing the sounds...
Does it make these sounds when your iPhone is not in the car with you?
tsfarling
no it only happens when its plugged into the aux and aux is selected
#1Tango
the aux makes that sound because its looking for a signal, so there is a hiss/buzz/static sound when you raise the volume or adjust the brightness of your dash lights.there was a thread about this like 2 years ago, tried finding it...
tsfarling
drove around with an ipod nano plugged in tonight and used the iphone and you really can't hear it once the music is playing. as long as you don't blare it the static really isn't loud. better on the ears i guess. thanks guys
superskunk
offtopic... hey dfc222 you should come out to a meet sometime... look in my profile for my email... hit me up!
maulik357
Car: Versa
Where did you buy the SL radio from? I am in confusion if i should get an aftermarket radio or get the SL one? Does the SL radio have builtin bluetooth?How much did you pay for it?
Return to “Versa Technical Discussions”
