swap or rebuild HELP
mr.domestic
Car: 1994 Salvage Camaro V6
I do not currently own a 240, but another member in my area is selling one. He said it does not run because the timing chain broke on the highway doing 80.He does know of an engine to replace it, but i want to know if it would be easier for me just to try to fix it. Bear in mind I am 16 and have limited financial recources but really want a 240. Also, what parts would i have to replace? Or is that something I would need a mechanic to tell me? PLEASE HELP!!!
Toshima
Car: 93 240sx, 93 sc300(m/t)
If the timing chain broke doing 80. Your proable going to have a prety good amount of damage on the head. But it also depend on how much the used motor is. Ifs its cheap buy the motor and then you can alway rebuild the old one if the good motor goes out.
mr.domestic
He says there is an engine available for $650 w/ about 66k on it and thinks labor to have it installed would be about $350.
popogto
if you got the time, try swaping it yourself. just need a cherry picker, some basic tools and download the FSM. and some friends to help
Toshima
Buy the motor and swap it your self. All you need is a decent scocket set, jack(use the one in the car if you can buy one), jack stands($9.89 at wall-mart), engine host(rent one). Its really easy my 93 240sx was the first car I ever pulled a engine from. Its really easy after the first time takes a few hours if doing it by your self(goes faster with a friend).
Flicktitty
Car: 1989 Nissan 240sx 2JZ-GTE Swapped
1994 Toyota Supra
2019 Lexus GX460
1992 Lexus SC400
by the new motor and swap it your self like everyone else has been saying.
thekawaii
Car: box with 4 wheels
Toshima wrote:jack(use the one in the car if you can buy one), jack stands($9.89 at wall-mart), ).
Very bad bad bad bad bad bad bad bad idea. Don't ever. It for emergency tire change. Don't use it. If you don't have money, rent high quality tools from kregen or Autozone for free.
(Some time, it DOES FALL)
How much your life worth? $9.89? NO.
