Swap NAV unit into my non-NAV equipped 2017 QX50
Discussion of Infiniti's amazing (and underrated) sport-luxury crossovers, the EX35 and EX37. For 2014, the EX series will be renamed QX50, in line with Ininfiit's new naming conventions.
cajunjon
Car: 2017 Infiniti QX50
We just bought our 2017 QX50 and found out too late that bluetooth equipped doesn't mean BT AUDIO. I found a totaled 2016 QX50 someone local is parting out that has the Premium Plus option pack with NAV to swap into my 2017 QX50 non NAV system. I have some experience swapping devices on other brand cars. I'm just unsure if it's only the Display and the AV Control unit that are needed to swap out or if there are other sensors, harnesses, control modules or ??? that I'll have to pull out.
Any guidance would be appreciated.
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
It's very unlikely that your Main Harness will have the connectors to support the Navi. From what I can see on the WD's, even if you have Bose you'll be missing at least one major connector plus the AVM module and its connections (and maybe cams too). You're talking about bigtime re-wiring if it's possible at all without new Main and Body harnesses.
Far cheaper to buy a BT adapter.
VStar650CL
Technical Expert
AZhitman wrote:
Wed May 19, 2021 3:55 pm
Trenchant as always. :biggrin:
cajunjon
Thanks for the help. :bigthumb: I've gone down this road before and that's what I figured. I know BTAUDIO is a popular complaint with several of the Infiniti models but I've searched a bit and haven't found an aftermarket solution to add Bluetooth streaming audio yet.
Maybe if there was a wiring diagram for the head unit or amp and I could tap in a 3.5mm or RCA connectors even. Any thoughts?
Check out these guys (several of our members have the GROM system) if you really want to exceed the capabilities of even the factory upgraded setup:
https://gromaudio.com/store/vline/nissa ... grade.html
sev
Car: 2010 Infiniti EX35
not worth the cost and effort for essentially and outdated system. plus the bluetooth in the nav system is only bluetooth 2.0+edr, pretty old standard. you'd be much better off getting a grom v-line or maybe the nifty city multimedia kit. that'll give you carplay and android auto. much more usable.
https://www.niftycity.shop/
OWC
Car: 2006 Infiniti G35 Coupe
2008 Infiniti EX35
It's very doable. See Here:
OWC
2008 Infiniti EX35
Here's the link for anyone interested.
https://www.ebay.com/itm/334295251786
Return to “Infiniti EX35 / EX37 and QX50 / QX55 Forum”
