Veloce wrote:i am going to swap my stock KA24E with a CA18det next month and was woundering what all needs to be done with the harness. will it plug into my factory harness as long as i have the CA ECU and full harness. i know that with the SR you have to do somthing special.. do you with the CA? if so what all needs to be done??
thanks.
Billy
The engine harness needs to be modified to match your USDM RPS13 chasis harness. If you can't wire it, please pay someone to do it for you because it saves a gang of major headaches in the end.
Dee
