Turbo Glennbohttps://forums.nicoclub.com/memberlist.php?mode=viewprofile&u=113Swap?? - I need a Interior Fuse Box and Generator HarnessTue Jun 16, 2009 12:52 pm
Postby
Turbo Glennbo »
https://forums.nicoclub.com/turbo-glennbo-u135624.htmlTue Jun 16, 2009 12:52 pm
Can anyone tell me what models/year Nissan and/or Infinity that I can get the alternator wiring harness and the fuse panel for the drivers side for my 1994 G20 ?? My car is in the shop and the mechanic needs these quick or I will have to buy them from his distributor. I have access to a local salvage yard that has a lot of Nissans and 2-4 Inifinity's in it. Any help much appreciated.
Postby
nissasin »
https://forums.nicoclub.com/nissasin-u136395.htmlTue Jun 16, 2009 4:31 pm
Depending if you have ABS or not the harnesses may differ. There is a large connector that goes to the ABS unit from the alternator harness. Also keep in mind you'll need from the alternator all the way over to the battery area harness.
Postby
Turbo Glennbo »
https://forums.nicoclub.com/turbo-glennbo-u135624.htmlTue Jun 16, 2009 4:43 pm
The plugin from the alternator to the plug on the wall mount is tore up so to me it seems I just need to replace this one section and not the complete run all the way to the battery. I hate electrical adn I know very little about it. Maybe I will just get the full run to be safe. Also I have ABS - I think?? I have had this car for a week and only driven it once and that was to the shop for repair.
Do you know if I find a matching fuse panel box how much of that harness I need to take? Is there a break in the run anywhere that I can unclip? I know some of it goes alonng the door to the rear.
