BaliLover »
https://forums.nicoclub.com/balilover-u6785.html
Sun Feb 08, 2004 8:30 pm
I bought my swap in April of 2003, but I just now got it finished due to other things in my life.
It has been nothing but problems and money down the drain. I bought the motor from Charlie Marcone in Orlando and when I showed up to get the motor, it looked a bit rough. It had a hole in the manifold for an external wastegate, the oilpan had been modified, and the trans was seperated from the engine. I paid partial with paypal and the rest in cash and got a little receipt showing that the motor was guarantted to start, run, and not smoke.
This is where the problems start. #1, the MAFS was for a SOHC, but I had no plug for it, so I had to buy one. #2, no Bellhousing bolts so I had to make my own. #3 oil pan had been modifed to keep oil at the pickup, but it also was about 1/2 qt less capacity so I had to get another oilpan. #4 Turbo extension was shot, someone snapped the studs off and had tack welded it to the turbo so I had to get a new one. #5, the oilfilter mounting (tube/shaft?) was partially snapped off when I removed the old filter, still functional though so I don't know if it counts. #6, no thermostat. #7, no intercooler piping of any kind.
So now I've got all sorts of upgrade parts, put them all together get the engine and trans together and in the car, get the wiring done, and discover that the ECU has no LED for diagnostics but seems to run the car fine, at least at idle. I go to take it for a test drive up the shops driveway, and find that the 2nd gear syncro is gone, can't force it into 2nd 70% of the time. Pull the trans, switch bellhousings with my KA trans, and put the new trans in. I finished all or this last night at around 1am. I take it for a drive to my house, about 15 minutes and it seemed to run pretty good but the turbo seems to not hold boost too wel, although I was taking it easy. I get up today and decide to take it for a longer drive. I drive for about an hour, oil pressure is good, temp is good, but I hear a light klacking noise. I stop at my shop to put my backseat in, and when I go out to leave, the klacking is a bit worse, more noticible. It sounded like it was coming from the head, so I figured it was a lifter.
I check the oil and its fine, pressure is fine, so I limp it back home, with the klacking not getting any worse. I decided later to drive the car back to the shop, but 5 miles from the shop, the klacking turns into a horrible sound, a spun rod bearing, the same thing that killed my KA. So now I've got a 240 with a freshly completed swap, with a spun rod bearing. I haven't yet tried to contact Charlie, whom last I hear was working at Racingworks.com in the Orlando/Winter Park area but I've found some complaints about him here on Nico so I'm pretty sure that I'm gonna have a hard time getting him to replace the motor.I have 2 e-mails for him and he replied to an email I sent him in August, and I bought stuff from his store on Aug. 29th, so hopefully he'll be willing to do something. If not, what are my options?
