swap done, but no spark and a few other questions, please help me out
clovers525e
Car: white 93 coupe, s14 sr
i just swapped a s14 sr into my 96 s14 and here are the problems i'm having.
ok, i did all the wireing on the f4 my self which wasnt too bad but i did have several extra wires, as i should. but the problem i'm having is after i got everything hooked up i'm not getting spark. i'm using a factory sr ignighter that was sent with my motor so i there shouldnt be any problem with that. how do i test the ignighter and the cas, how do i time the cas since there isnt any spark plug wires? and there are two cut wires sticking out right before the ignighter, are these for the boost sensor and do i need to put them togather or leave them appart?
there are three wires coming out right before the maf plug, i think one is a powersteering pump pressure signal, ones for the ac compressor and the other i dont know about but i need someone to confirm this too.
i put my finger on one of the injectors and had a friend crank it over and i couldnt feel it click, but when we cranked it you could smell the raw gas so i think they are fireing. i'm not getting any codes besides 55 so the ecu is in working order and has no detectable problems.....
i'll post up some pictures when i get home but if anyone can help me out that would be awesome, i think its the cas or ignighter but any other problems that would result in what i'm dealing with would be nice to know about...thanks a bunch in advance
slik_s13
Car: 1990 nissan 240sx hatch back
use the heavy throttle sr install faq to figure out your wiring problems. im sure that should help you also frsport has one on there web site. gl
