I H8 UR DSM »
https://forums.nicoclub.com/i-h8-ur-dsm-u121.html
Thu Oct 17, 2002 6:41 am
i have seen people missing or bad ignitors (up to 500), dented oil pans (up to 300), bad ecu (up to 500), i burnt my clutch up in 3 hours (250), gaskets either burnt or missing (100), all the oils and fluids(i like to do swaps, new oil, run for a day, then drain and replace), then there is always the stuff you realize you want, like water temp guages and oil press etc....it gets expensive, youll see....i know when i did mine i kept getting more and more stuff....you can do it inexpensive, and stock, or you can do it up, and spend money....i have you a large gap, and 2000 at the high end, but yes, i can see people getting the motor, and labor money, but still spend another 2g's on parts and accesories, and gas, spark plugs, etc etc etc etc : D
