im still working on sons car 95' j30 . checking the abs sensors found out the lower control arm joint is bed . boot all tore up
first . i read somewhere - the ball joint can be replace with the "ball joint press" which i can get at autozone and also can get a 300z's ball joint which is the same at usautoparts.com i dont want to buy a used control arm from ebay would like have a new ball joint so to avoid future problems ,im still have to remove the lower control arm
has anybody remove this arm before and will i have to remove the bearing hub to remove the arm . i cant find any detail instructions on the service manual . thanks a bunch again
