Suspension upgrades hot or not?
240 drop top
My vert is needing some help in the suspension area.So before I go and drop a boatload of cash I thought I would ask my vert brothers to share their experience.What upgrades/repairs have you done to your cars suspension or bracing?How effective were those versus the cost?
I did TEIN S-techs and KYB GR-2's. Cheap upgrade, dropped it down nicely, and handles wonderfully.
Hijacker
Car: '92 240sx Convertible
'94 F-150
I have Tein S-Techs and KYB AGXs. Well worth the money. I also have a front STB, which did help out in the stiffening up the chassis substantially.
Further upgrades will be SPL fender braces, a rollbar, and sway bars.
spinout180
Car: 1992 Nissan 240SX
I have the AGXs also and love them. Combined that with the Suspension Techniques springs and swarbar set. Handles pretty good, although I might go back to the stock front swaybar to try that out...
Darren
240 drop top
Hey thanks for the replies.I'm going to check out the AGX's.I also found a racing machine shop that will make me a brace connecting the front shock towers and the firewall.
den240
Car: 92 ca18det cnvt
I've got the s-tec springs (about $100) and KYB gr-2's (about $180) like AZH. Only dropped it about 1 inch (didn't want any more drop anyway!)
It's pretty rough on bumps, but does handle well.
HUGE upgrade when I put on thicker anti-sways (about $180). (sus-tec also) Went from.... I think about 23mm to 32mm in front and 15mm to 25mm in back.
I'm not sure if I'd go with the AGX with the s-tech springs. I think maybe the springs are too stiff to take advantage of the adjustable shocks...
Maybe the order to do these things in if on very tight budget: 1. struts2. anti-sways3. springs(that's the order I now think I should have done it in )
Modified by den240 at 1:15 AM 9/7/2004
Hijacker
'94 F-150
If you think the AGXs aren't strong enough to handle a set of S Techs, then your GR-2s definitely aren't. I can personally say that the AGXs are fine with S Techs. And since they're adjustable, you can smooth the ride out by stiffening the damper. Stiffening the damper allows the spring to do its job better and keep the damper extended. A softer shock will allow the spring to compress too much, increasing harshness in the ride. While my ride isn't the smoothest out there, it was a lot worse when I had my shocks set to 1 and 2
kppk1986
Hitman do you have any pics of your car with that suspension setup... i was thinking about getting the same setup and i wanted to see what it looked like??
Yep, they're on Photopost and will be up in a day or so. Looks real nice.
kppk1986
how do i see them on photopost... im a nub, what is photo post?? well other than a place to post photos...
We're still in the process of importing all our pics - We just moved....
Give it a day or so.
toptechracing
Car: 98 Nissan 240SX race car
93 Nissan convert
I will have to say don't over look a good Koni setup. I have tried a lot of different and very expensive shocks on my race cars and have always ended up very happy with the performace of the Koni's
Joe
