ok, heres my questions.Im getting ready to start on my suspension setup and am looking over different options for coilovers, wheels, and tires. ill start with my wheel questions.
wheels -1. since i will use this for autox somtimes, i should have same diameter / width wheels on all 4 corners, as opposed to wider in the back, right?
2. as i mentioned in goals for the car, i want high stability in corners. oversteer at high speeds freaks me out. wider wheels would help prevent oversteer by adding more contact patch, correct? how wide can i go? I am guessing 9-9.5 is about as big as you can go before the wheel starts sticking a good ways out of the wheel well? if you can do larger without problems, could somone please correct me on this?
3. as for diameter, is there any performance related reason to have a larger diameter wheel? i see lots of posts of people who want 18"s etc. is there a reason for this aside from increased bling factor? what is the smallest diameter you can do while still clearing z brakes, and would this be a smart choice?
4. what is meant by a wheel having a polished lip? i could never figure out what this was.
5. anyone want to suggest a wheel after reading all the junk i typed?
coilovers-
please help on this, i am trying to understand the many intricacies involved with suspension, but there is too much information. please give as much information as you can while i go scrounge for more info on the net
1. why would one go with a coilover setup instead of just upgraded springs/shocks? the only reason i am able to get out of my friends is "because coilovers are better". is it because they are adjustable? or have better spring rates? or...? please help.
2. http://www.jic-magic.com/armnrod/armnrod.htm what is all that craziness? i havent been able to find much specific information on what control rods are, how they work, etc. so any info on that would be very much appriciated.
tires- edit - havent looked into tires hardly at all, so i wont bother wasting anyones time with questions that have probably been answered already.
misc-
where can i get derlin bushings? i have heard this is the stiffest material bushings are available in?
