gumby »
https://forums.nicoclub.com/gumby-u10614.html
Thu May 05, 2005 3:35 pm
is it just me or does none of the hardware they send you fit correctly? Ive got the front bar ready to go.
since the brackets are thicker you cant reuse the original nut. no problem just grab the one off the endlink.
instructions say use 2 washers under the rear bolt hole but on a flat surface it looks like it could use 3 to level it off.
the heads on the bolts they send with it are 17mm so i cant get a socket on it so forget about torquing it and it looks like an open ended wrench is a tight squeeze, but i cant even get it threaded in by hand. the last thing i need is a crossthreaded bolt.
so im gonna try it again with the 2 washers and see if it makes a difference. otherwise im thinking about reaming out the front bolt hole.
i dont think im cut out to be a mechanic
