I was kind ahoping for a more detailed response.....
Just kidding!
Q45tech, you are amazing! Thanks for the info. in a precise, understandable format.
I am convinced I need the Tokiko Blues, and want the active rear sway bar. I already have 17" wheels, and high performance tires. Do you see anything I should do, in addition, to hel provide a balanced handling upgrade?
I do not intend to put Eibachs on the car, but I might try to shave a 1/4 turn or so, off the original springs, when I install the Tokikos, to lower the CG. It would not take much to talk me out of doing this, if you have an opinion.
George Akin has a set of Tokiko blues, from his '91 Q. I knoq the rears are the same, but the fronts have a different part number for my '94. Is this a significant difference?
