suspension
JT$240
Car: just a 1990 Nissan 240sx
well i recently installed new OEM tensions rods on my 1990 nissan 240sx. mainly because i was hearing these really loud clunking noises when ever i was braking or accelerating. so the sounds aren't as loud as before but i still can here some clunking once and awhile. so i'm wondering what bushings would be next to fix after the tension rods? i think since my tension rods were shot that they put more wear on some other bushings and after a month of driving it with blown tension rod bushings i think some more bushings need to be replaced??? hope someone can help me out, thanks
jmauld
Before buying anything else, check to see if your engine mounts are loose.
Other then that, the parts I would look at next are:- Anti-Swaybar bushings and endlinks- Front Upper Strut mounts.
