Suspension
Daknak
Car: 300zx
So I'm purchasing the Tein Z flex coilovers here very soon. I don't know much about suspension but I'm pretty damn sure I can't just buy coilovers and lower my Z a couple of inches without something breaking. What other parts would I need to lower mah baby girl. Thanks in advance
NolimitZ32
Please search, this topic has been covered many many times.
DevilZ32
Car: 1992 Fairlady Z (Z32) TT
1994 BMW E36 325i (currently doing an S50b30 swap)
Daknak, as NolimitZ32 said, this topic has been covered many times, but I will give you help since I'm here anyway. In short, just to lower your car and get a slight boost in handling and all, you'll just need coilovers. Tein's are good but you coilovers with rubber/pillow balls. I'm not sure if the Flex Zs come with rubber/pillow balls. These balls will be beneficial because you won't have to use the ones that are stock which can potentially be worn out from driving the car since it's not new. To my knowledge, they also won't be quite as durable compared to rubber/pillow balls. They will be ok but you don't want to push them hard, if you do, again you'll want rubber/pillow balls. Do know this will automatically make the ride stiffer. Hope this helped!
NolimitZ32
You don't NEED coilovers unless you track the car and need the adjustability. If you want a little drop you need springs with a "little drop" if you go past 3/4" or so you should get adjustable arms because the factory camber adjustment will be insufficient, or you end up rolling HERRAFRUSH. That's the short of it.
Ace2cool
Car: 1991 Nissan 300ZX TT
1966 Datsun Fairlady 1600
2005 Suzuki GSX-R 600
1974 Honda CB550 Four
2009 Ford F150 Lariat
I mean, mine is slammed with no adjustable components. Tire wear is terribad though.
DCaff300ZX
Car: .
1993 CRP TT- Modified
Ace2cool wrote:
Wed Nov 01, 2017 12:49 pm
Yep, no adjustable FUCA/RUCA and the tires be ridin on the sides (OK, edges)... :chuckle:
