Suspension
wolvehouse
Car: 1989 Nissan 240sx
hello everyone i recently just bought godspeed rs coils and godspeed camber arms, godspeed inner tie rod arms and godspeed traction arms. was wanting to know what else i need to run crazy camber. i know this is a prob a noob question but im new to the whole camber life haha so your answers would be greatly appreciated. as well to the front of the car i just bought adjustable lower control arms and high tension rods. what else would i need to run crazy camber in the front?
Ajax
Car: 1991 240sx SE
2010 Mazda 5
throw all that stuff on and don't get an alignment? That could be some crazy camber...
If the coils came with adjustable camber plates, then that will be your easiest adjusting point.
Hijacker
Car: '92 240sx Convertible
'94 F-150
TBH, buy better quality components. Crazy camber puts a lot of undue stress on suspension components, and Isis quality isn't that great. You'll see rod end failures with them trying to go too negative. But, you'll need adjustable FLCAs to stretch the track width as the upper camber plates won't net you too much. In the rear, you can get a decent amount with the RUCAs, If you didn't nab rear toe arms, you're going to find that you won't be able to go too negative as the toe in will get horrendous in the rear.
metalmagician
Car: 2010 Nissan Altima 2.5s Coupe
what do you consider crazy camber? I run a -3ish all the way around and I consider that pretty steep. I got that out of a coilover kit with camber plates
