moso »
https://forums.nicoclub.com/moso-u137641.html
Sat Aug 20, 2011 9:32 am
As much fun as replacing all those parts sound, the 240 will drift perfectly fine completely stock. provided its in good shape. replacing suspension parts and upgrading to better performing parts is recommended but not necessary. Seeing as your clearly a novice my recommendations are as follows.
1- start with a happy motor, fix any broken parts, general tune up
2- check the stock braking system, fix any broken parts (most upgrades are from other stock nissans and tho it is reccomended to upgrade the stock system is perfectly fine for a beginner)
3- check the stock suspension, replace any worn or broken parts (any time is a good time to upgrade suspension, i suggest aftermarket struts and springs for beginners as coilovers can be expensive and difficult to adjust correctly) pay particular attention to the stock rubber bushings as they tend to go bad and will make the car tough to control during a slide. I suggest the Energy Suspension bushing kit along with some sort of rear subframe bushing kit.
Once you have completed those you can move on to more radical upgrades such as a performance clutch and flywheel combo, well built exhaust, big brake packages, and so on. Keep in mind that every modification you do is going to have an effect on how the car performs on the track as well as affecting its overall reliability. Modifications take time to get right and can often take longer than you initially expect. Also keep in mind that no upgrade is going to make you a better driver, If you dont have the skill to pilot your car, making it more powerful and more drift happy will only make it more difficult on a novice driver.
