hksdrift240 »
https://forums.nicoclub.com/hksdrift240-u143017.html
Sat Nov 14, 2009 8:55 pm
Can a left front strut be used on the right side? I assume the only difference is the brake line bracket that is reversed? Its on a 95 240. I have hks coilovers and the front ones are so stiff that the front end just bounces when you hit bumps, or on roads that arent perfectly smooth, and im getting tired of it. If you push down on the front end, the tire is the only thing that moves, and the coilovers are set to full soft.
