suspension
avilas
Car: 90 Talon TSi AWD, 91 q45a
is there an on/off switch for the suspension?
avilas
i dont know whats going on, when i start the car the front suspension raises like it should but a couple of seconds later the right front side drops down and the left stays raised, and if i turned it off the right raises again.
Modified by avilas at 8:55 AM 9/17/2007
96Qowner
Car: 1996 Q45
The first thing you're going to want to do is check the system's self-diagnostics. If you don't have a FSM, you can look at and download the pertinent sections here: Look in section FA under "Full Active Suspension" and "Trouble Diagnosis for Full-Active Suspension System". Then run the diags.
http://www.nicoclub.com/FSM/Q45/1994_Q45/
For some background, read through these threads:
zerothread?id=277075
zerothread?id=230687
If you have some time, you can learn a lot about the Q45a and its high-tech suspension from Searching NICO. Start by reading all the threads with posts from "texasoil". Be sure to click on "post bodies" and search both "archived" and "recent" threads. That's 2 separate searches.
avilas
whats an FSM? I tried that self diagnostics and the ACTSUS light would flash repeatedly in sets of 4, what does it mean? and instead of the right side raising back up the left went down and now the whole front is dropped. PLEASE HELP!
96Qowner
Car: 1996 Q45
FSM is Factory Service Manual. The place I pointed you to has the manual online. Click on the file named "fa.pdf" and read the sections I cited. The diags section willl tell you what the flashes mean.
avilas
whats consult?
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
avilas wrote:whats consult?
Please start by reading the Owner's Manual and the FSM. Then try a few searches before asking questions.
The good news is that TexasOil is in houston.
http://www.q45asuspension.com
96Qowner
Car: 1996 Q45
Consult is Nissan's proprietary diagnostics system. Any Nissan or Infiniti dealer has it and can use it to check any of the electronic systems.
Similar to an OBD reader.
96Qowner
Car: 1996 Q45
maxnix wrote:The good news is that TexasOil is in houston.
It looks like he's letting that URL go, Brian - it hasn't been renewed. This is the more comprehensive site:
http://www.activesuspensionsystems.com/index.html
texasoil
Car: '92 Infiniti Q45A
'94 Infiniti Q45A
'94 Mercedes-Benz SL600
Hey I did renew registration of my Q45asuspensionsite--I need to check-I paid those turkeys good hard money.Anyway stuff on both sites.
