Suspension - Slow Speed Torture
Discussion of Infiniti's amazing (and underrated) sport-luxury crossovers, the EX35 and EX37. For 2014, the EX series will be renamed QX50, in line with Ininfiit's new naming conventions.
Rfong
My EX35 is almost the perfect vehicle, except there is one glaring fault.
The suspension is extremely violent at slow speeds going over driveways, potholes, transitions and changes in pavement, and street car tracks. This only happens at extremely slow speeds. Going over these types of surfaces results in violent hopping and oscillation of the car's body. The motion is violent enough to knock a lightly held water bottle out of your hand.
Of course the dealer says this is normal after two visits. I changed from 18" wheels to 17" wheels and that helped a little. However, I still cringe and hang onto the steering wheel when approaching a bump.
Does anyone else experienced this?
kullenberg
What tire preas. are you running? I keep about 35 psi, which seems a good compromise between ride and economy.
jmess
Not normal, you may have a bad shock absorber or something loose. If the front end alignment is goofed up it can cause some strange behavior also.
If you take somebody for a ride from the dealership it should be pretty easy to reproduce.
The local traffic freaks installed speed bumps in my neighborhood. So my suspension goes through a bump test every day. I find my EX handles the bumps really well.
Rfong
I'm pleased to report that after many failed attempts with my dealer about my harsh suspension, the problem has been fixed.
However the solution was completely a surprise.
I have followed Steve the Tech's thread about the steering problem with slight groaning during right turns. My car exhibited these symptoms so when the TSB was published I took that information to my dealer to replace the steering rack.
The part had to be ordered but after 4 days, the work was done. It did remove the groaning noise and steering vibration, BUT the BIGGEST benefit was it eliminated the harsh suspension that I complained about earlier this year. The ride was much softer and the bumps were muted and the abrupt oscillation was gone. Even my wife who winched in pain on every bump said the ride was much improved.
The steering rack was apparently responsible for the bad suspension.
How do you figure the steering rack could be related to harsh suspension?
Anyway I suffered for one year before the problem was fixed, now I can enjoy the car.
Rfong wrote:My EX35 is almost the perfect vehicle, except there is one glaring fault.
kamiguy
Car: 2008 EX Scarlet silver wheat interior.. all options
So glad that you are happy with it now. I wonder if the techs found something amiss with your car when they replaced the rack and didn't mention it to you?? Just a thought...
rayc325
Car: Platinum Graphite EX35
Platinum Graphite FX35
Rfong wrote:I'm pleased to report that after many failed attempts with my dealer about my harsh suspension, the problem has been fixed.
I wonder if this also causes the suspension to sound as if it is coming apart. Mine sounds like it is all loose going over a rough surface. Is there a link to Steve's post you refer to? Thanks
SteveTheTech
Car: 15 Nissan Sentra SR
12 Infiniti G37x Coupe
-Formerly-
05 Mazda 6 L3 Sport
95 Infiniti J30
94 Nissan D22
Ron has had some very unique issues with his EX and I think his issues have been resolved for the most part with the replacement of the rack and pinion. I have never personally had the pleasure of evaluating this condition but it was very aparant that there was an issue like nothing I have personally seen.
Even the EXs I have worked on that were in fairly serious collisions have not had any rattles. If you have driven down a road with dirt or rocks you may have one caught somewhere that is either itself contacting something that is moving or forcing some component against another. If the noise changes pitch or frequency or gets louder I would make an appointment to have it looked at sooner rather than later.
Return to “Infiniti EX35 / EX37 and QX50 / QX55 Forum”
