thekage »
https://forums.nicoclub.com/thekage-u15476.html
Mon Apr 04, 2005 9:50 am
Im in the process of rebuilding my 89 hatch.Coilovers are out of the question at this point in time. I have 17s and a set of 16s. I was thinking of going with a set of Tein S-Tech Springs for a drop.. KYB GR-2s with a Cusco or Tein Pillow Plates for some camber adjustment in the front and also a set of Tein Tie Rods. I am not sure if camber is going to be a problem in the rear or not.. But control arms will correct that if it is a problem right?Strut bars front and back as well.
Do you think this setup will be decent for a daily driver with moderate track use?
What are tension rods? Same as tie rod?
