Suspension Set-up
YasiAngel
What's a good suspension set up for a 240sx (91 fastback LE) that will be used for some drifting/some daily drive?TEIN Type HE damper a good choice? :confused:
bvanev
Car: Cars, Snowboarding, photography, Cars
I have the tein FLEX type coilover set-up in my car and it is great for intense driving. The ride can be a little brutal on rough streets. In fact the first time I drove it for an extended period of time I got a headache cause the ride was so brutal, but they were really poor roads. I have never experienced the HE type coilovers, but from everything I have seen they are a stiffer ride. I do suffer from a little bit of wheel hop, a larger profile tire should solve that problem though. Good luck, just make sure you do it right the first time, it sux to waste a lot of money on a coilover set-up if you don't like it.
