Suspension set up
giodachamp
Car: Nissan 240SX S13 (180SX)
I recently bought KYB AGX struts and i was searching and some people said that if you pair up this struts with eibach sportline springs, it would ruin it. If that is the case, can i put the eibach pro-kit on it..... any suggetions would help (no coilovers since I can't afford one yet =(...)
Thaddeus
Car: 1998 240SX se 1984 Porsche 944
This is an excellent post... for the brake and suspension forum.
giodachamp
yeah but no one replies there
adrianfromthecastle
Car: 1992 Nissan 240sx
Thaddeus wrote:This is an excellent post... for the brake and suspension forum.
zzzzzzzzzing!
giodachamp wrote:I recently bought KYB AGX struts and i was searching and some people said that if you pair up this struts with eibach sportline springs, it would ruin it. If that is the case, can i put the eibach pro-kit on it..... any suggetions would help (no coilovers since I can't afford one yet =(...)
yeah, your fine with pro-kits... reason being is that sportlines are too low of a drop for most shocks that they tend to blow after abuse...
giodachamp
adrians_s13 wrote:zzzzzzzzzing!
thanks..... i'm going right now to get one
AceInhole
The Konis were fine with the original design Sportlines (but the Koni yellows also damp better than the majority of/ all JDM coilovers).
The Sportlines were later revised for use with cheaper shocks/ struts such as the Tokicos and KYB's. IIRC the drop was reduced by some .5 - .75" (no longer the 2.5" original drop). The newer models should be fine, if they're even still selling them.
