Near the top with the rust is where its rubbing. Its hard to see without the wheels off, but I'm not taking the wheel of without being in the shop. Also it started raining so I didnt check for any play.
Thats the wheel. We were told its stock.
So if everything is factory then there should be no need for the spacer, and the only thing that I can think that would cause that is a worn component causing the suspension to sit incorrectly.
