180fan »
https://forums.nicoclub.com/180fan-u3602.html
Sat Mar 17, 2007 6:56 pm
My suggestion: bushings first. if you've an s13 and never fiddled or replaced any of the bushings, I can assure you they're most likely blown.
A couple of builds depending on modifications to your car. This is also taking into consideration your tie rods and tension rods.
stock: bushings, inner and outer tie rods, lower control arms for both front and rear (front are more consistently bad though at the ball joint), your stock struts are probably blown (look into stock replacements like tokico blues or kyb gr-2's), and the tie rod boots.
lowered: Depending on how severe your drop is, you may want to consider rear upper control arms and toe links for the rear, bushings, sub-frame bushings or spacers, again tie rod boots, both front and rear ball joints, struts with newer struts made a little more resilient (kyb agx, koni yellows) or budget permitting coilovers.
