Okay, first thing. DO NOT GO TO PEP BOYS EVER EVER EVER EVER except to buy wiper fluid and wax. Okay, was that clear. Again, Pep Boys should never be allowed to touch your car with any tools of any kind, period. Still do not believe me. DO NOT GO TO PEP BOYS!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Okay, now that this you have digested this, don't tell me about how Pep Boys fixed your Ford or any other car. They suck, period.
Next, suspension on a 97's is shot. You should use the search as I have personallly posted this information a number of times, but I will give you the skinny. There are no aftermarket shocks/struts in the USA available except the OEM ones. Those are very expensive and are not a DIY situation as the front struts require special equipment. The only aftermarket (much better) aftermarket shocks/struts are only made for the Japanese market, but can be sourced from a place called memoryfab. Call them and inquire about KYB SR Specials. KYB makes the OEM replacements for the car anyways, the SR Specials are imported from Japan so you need a special place that imports them Japan. This means you cannot go to any place to get these unless they know how to do special imports to Japan. Thankfully for you Pep idiots cannot find these so they just saved you from a fu$%up they were sure to pull off.
My advise, call memory fab, buy SR Specials and call Z Expert in Venice, CA, ask for Richard and get him to install them. There are some other good places in So Cal depending where in So Cal your at, but please, save yourself and everyone the pain of Pep Boys.
The other altearnative is OEM for more $$ and less quality, but again, not installed by your pep boys.
Any further info PM at
[email protected]. I have 97 with those shocks and lower springs......
