Suspension replacement advice needed.
hyl768s
Car: 1997 Q45T Black with 80K miles
Hi guys,
I replced my 97 Q45T stock springs with Tein 2" drop on 4 coners. With 18" wheels and 1" spacer at front, now my Q looks much hotter, but after about 4 months, the 90K miles suspension finally quit. Lockly I already have the KYB special inhand and ready to install. The problem is I have no idea which bushing I should buy since I assume my stock 90K miles bushings are getting old as well. Is there anyone can advice me the parts I need to complete the job? Below are the parts I'm planning to order.
KYB Strut Mount
Front Sway Bar Link ( http://cgi.ebay.com/ebaymotors...&rd=1 )
2 REAR Sway Bar kit ( http://cgi.ebay.com/ebaymotors...&rd=1 )
Moog Strut Bellows ( http://cgi.ebay.com/ebaymotors...&rd=1 )
I think I mistake and missed many parts for the job. Please kindly give me any advice to help me not to waste my money
Thanks
PS: Anyone need 97 Q45T stock spring? Let me know free of charge. I also have a 6 months old 350Z stock fly wheel. Free as well. Let me know if anyone interested. ( Ilive in So CAL)
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
http://www.infinitipartsusa.com
All else is a crapshoot.
hyl768s
Thanks Maxnix,
I'll give Joe a call today for sure. How about those parts I found from e-bay? Are they worth the money?
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
maxnix wrote:All else is a crapshoot.
Read Wes' posts on modifying (using 3rd party parts) for a G50 suspension.
Many pitfalls, so I wouldn't approach it willy nilly. The rear link set up might well work, and if it doesn't, easy and insepensive enough to replace.
Get the factory boots with bumpstops for about the same price.
96Qowner
Car: 1996 Q45
But this is a FY33, a 97t, right?
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
96Qowner wrote:But this is a FY33, a 97t, right?
Oh true, but even more then.
Be sure to have front bearings and spring mounts also on hand in case you need them.
hyl768s
Ya, mine is a FY33 Q45T with 90,000 miles on it
hyl768s
Thanks for the help Max, How about the front sway bar link?
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
The stabilizer connecting rods? That's a good question. Mine was too young, but you might inspect them first to see their condition. I have no idea if the bushings are avaialble separately.
qship96
Car: 1996 Infiniti Q45
I`m sure you can purchase the swaybar end liink bushings from joe-he sold me the end link bushings and frame bushings for my 96 swaybar-just a few dollars if I recall
hyl768s
How about Energy Suspension bushings for a 90 to 96 300z, will they also fit the 97 Y33 T ??
maxnix wrote:Oh true, but even more then.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Maybe on the rear. Might increase harshness.
There is an interesting post about different rear sway bars on the early FGY33.
hyl768s
OK, finally got time to call Joe. Like everyone said, he is very nice and very helpful. Below is the quote I received from him yesterday. I believe Joe gave me the best price he can offer, but oooouch for #2 and #4 What are these things?? Any one have picture of it? I guess #4 is a plastic cover (tube) thing that help to against the dirt and water, but I have no any idea about insulator thing. Anyone knows??
Part Number qty Description UNit Price Ext Price
1 54050-4P702 2 BUMPER ASSY-BOUND $18.13 $36.262 54320-6P010 2 INSULATOR ASSY-ST $40.43 $80.863 54325-4P001 2 BEARING-STRUT MOU $16.69 $33.384 55240-0P000 2 BUMPER ASSY-BOUND $31.41 $62.82 5 55248-2Y000 2 COVER ASSY-BOUND $6.24 $12.48 6 56217-61L10 2 BUSH-SHOCK $1.93 $3.867 56218-61L10 2 BUSH-REAR SHOCK A $2.54 $5.08 8 54613-6P014 2 BUSH-STABILIZER $5.20 $10.40 9 54613-04F02 2 BUSHING STABLZR $5.72 11.44
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
They incorporate the bump stops.
Now go price at your dealer.
hyl768s
Hey, guys,
I'm still doing my homework and searching around for the prices, but I found out something weird. The price Joe provide to me is higher than the price that order directly from their web site. Is this normal?
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
No, he'll give you the lower one if you point it out to him.
hyl768s
Today I brought my Q to the garage near my home and the machnic showed me that my tension rod bushing and engine mount are also going bad. Can anyone tell me if my 97Q45T be able to use Z32'a tension rod? Is there any better engine mount that I can use to replace the stock mount? Can I just replace the bushing of the tension rod to save some bucks?? Thanks for all NICO member's help.
Haitian_King
Car: 1992 Black Infiniti Q45 /w TCS
1995 Black Infiniti Q45
hyl768s wrote:Today I brought my Q to the garage near my home and the machnic showed me that my tension rod bushing and engine mount are also going bad. Can anyone tell me if my 97Q45T be able to use Z32'a tension rod? Is there any better engine mount that I can use to replace the stock mount? Can I just replace the bushing of the tension rod to save some bucks?? Thanks for all NICO member's help.
I thought most Z32 stuff was better suited to G50's. Are they compatible with FY33's too?
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Buy the bushings from Joe. if you want, specify the Nismo polyurethane bushing.
Modified by maxnix at 5:03 AM 3/24/2008
hyl768s
Hell Max,
I spend several night to search possible solution and looks like I found a pretty good solution from other forum. Please check out the link below.
http://www.luxuryjcars.com/for...=1128
http://www.luxuryjcars.com/for...c=869
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Disconnected sway bars? Smaller bearings form lighter cars?
Not sure I see any reasoning here.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
All the 240sx/Z32 stuff will work in the rear, with the addition of front tension rods. The J and Y33 use basically the same front suspension so i wouldnt be surprised if the sway bar links worked..
I run energy suspension end links in the rear. They make universal end link kits, dont confuse those for the bushing kits... The 1 inchers should work, ive got it in my posts somewhere. Im using rubber frame bushings with the poly end links and it seems fine to me, i really didnt notice much change in harshness..
djguilty
Car: 99 Q45T pearl white
hey guys, any idea what i can do about my blown shocks on my 99 Q45t? i really don't want to get them form the dealer, big $$. thanks
hyl768s
This is where I got mine, but mine does not come with active suspension.http://www.memoryfab.com/produ...on_11/
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
djguilty wrote:hey guys, any idea what i can do about my blown shocks on my 99 Q45t? i really don't want to get them form the dealer, big $$. thanks
You really have no choice unless you want to convert to the nonadjustable but more expensive KYB SR Specials.
djguilty
hows the ride in the sr's? i'm looking for a solid shock, i'm what you call a spirited driver lol
i also herd that the oem shock is good but when you go to a non touring model shock or after market, the ride quality goes out the window. i have a 99T true or false?
basically i'm looking for a firm shock but i'd like to keep some ride comfort.
btw i did call memory fab and they said they don't carry a shock for my car.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
The KYB SR Specials with Eibach Sport springs are little sudden in transitions for the first 5K, but improve after then. Good control, but not cushy like stock
With a t or ae, I wouild keep the system intact and go with OEM.
djguilty
can i use the oe springs with the kyb sr's? or do i have to change it all...
what do think are better the tein's or eibach?
hyl768s
Installed My KYB special and Tein 2" drop spring today. The feeling of the ride is about the same like my 2003 350Z with 265/40/18 tires. I won't say it's a confi set up, but it match my driving style.
djguilty
what if i leave the stock springs. that should keep it decent but firm right?
