elpiar »
https://forums.nicoclub.com/elpiar-u47986.html
Fri Sep 26, 2008 5:09 am
My S13 pulls to the left during braking (or I can compensate by steering to the right to compensate). I rebuilt the front calipers, and replaced the tension rods to no effect. It seems like it's going worse. The guy who did my alignment told me that all the suspension is tight, no worn out ball bearing, etc. But I'm questioning that.
Help me sort these possible causes in order of its likelihood to be the primary cause:- Lower control arm bushing- Lower ball joint- Tie rod ball joint- Steering rack bushing (the previous owner told me this is already replaced)- Rear brake caliper pull- ???
