Suspension Questions.
miamiheat3332
Car: 2002 Nissan Pathfinder SE - 2006 BMW X5 4.8is - 2001 Audi A4 1.8T Quattro Sport
Hey all, so i have all my suspension parts picked out, coils, struts, and shock absorbers,
im ordering all those from 4x4parts.
now i have a few questions, i've been searching around and seeing what else i need.
What i have came up with so far is 2 kits of the strut mount assembly for pass and driver side from courtesyparts.com
and i think i also need bushings for the rear, along with the bolts for the absorbers in the rear, but im not entirely sure
for all these mounts and nuts, i rather got OEM and get them from courtesyparts.com
So anything else i need for suspension mounts / bolts etc. i would like to know. Or the links or item numbers of the parts.
Thanks.
EDIT: also do i need a spring/strut compressor to rent or a coil compressor?
Modified by miamiheat3332 at 11:46 AM 6/20/2009
miamiheat3332
anyone?
fueler
Car: 2 Nissan's
2 BMW's
list looks good, might wanna look at the condition of the dust boots and replace those if they look frayed and yes you will need a coil compressor for the front, in the rear i think you can get away without the use of compressor since you will be changing the shocks you can drop the axle far enough to replace the springs by hand
miamiheat3332
thanks, for clarifying which compressor i need, and then also, which nuts, bushing etc, do i need to replace in the rear, cause i remember reading a post on here mabye it was about the nuts on the absorbers in the rear being really hard to get off, and if you get s***ty ones they can break on the road.?
pretty much to clarify what i need for the rear and im good.
fueler
Car: 2 Nissan's
2 BMW's
i bought the bolts at the dealership just to be safe. all i remember is they were not cheap.
miamiheat3332
ok thanks again man.
So, so far i got
CoilsStrutsAbsorbers
all that from 4x4parts
2 strut mount assemblys
from courtesyparts
Get the nuts, washers, bolts and whatever else i need for those bolts
from dealership.
Rent a coil compressor,
and lastly, do i need any bushing for the back? since i rather put them in now instead of taking it all apart again later.
N2mesnob
Car: 95' SE Pathfinder
Surprisingly try Amazon.com for parts you may be surprise what you'll find there, I know i was and my rig is a 95'.
miamiheat3332
anyone else with the bushings? lol
fueler
Car: 2 Nissan's
2 BMW's
are u talking about control arm bushings?
miamiheat3332
yeah. wait are those the long ones on the sides, panhard rods or something? just want to make sure im thinking of the right thing
Buzzman
Car: 2016 Lexus RX 350
2023 Kia Stinger Elite V6 AWD.
fueler wrote: and yes you will need a coil compressor for the front,
Fueler, do you know if you need to have a wheel alignment done after replacing the front struts?I've had conflicting advice on this one.Thanks.
Empty V
Car: 2001 Infiniti QX4
1982 Chevy Corvette C3 Shark
I would, chances are you'll also need a camber kit for each side as well.
Billy
fueler
Car: 2 Nissan's
2 BMW's
im not the person to ask cause i had a weird story. For many years, no alignment shops could make my car drive straight. I went to the best of the best and my QX4 always pulled right.
after i lifted it, i got an alignment done and all of a sudden it drives straight. Like it was meant to be
miamiheat3332
any response to my question?
